Tons of static
  • couch.lock
    • 297
    Tons of static
    So I just installed my amp yesterday which is this http://www.crutchfield.com/S-py1OMlf...-MRV-T420.html
    Something isn't right though. I'm getting a ton of static, even when the car is off and music isn't playing. I thought that the problem came from the settings on the amp, but no matter how much I tweak them I can't get anything to work. I also tried testing the amp on different speakers. Even when I disconnected the RCAs the speakers still produce static. I read that static can be caused from a bad ground connection. My ground is going to the same piece of metal that the negative on my battery is hooked onto.
    So bad ground or bad amp?
    Additional information:
    On the amp there are two switches, one is a LP filter and the other a HP filter. If I have the HP filter on and the LP filter off the static persists but the music is very quiet. If I have the HP filter off and the LP filter on the static persists but the music sounds right. If I have both of them on the static goes away but so does the music. Also, for the speakers to sound good at all, I have to turn everything all the way up. Gain, bass eq, and both crossovers. Isn't that stuff supposed to be pretty low when you're running an amp to speakers?
  • couch.lock
    • 297
    Just to be clear, I don't have the amp grounded to the battery. I have it grounded to the piece of metal on the chassis that the negative from the battery goes to
    • IRON-E
      • 16548
      Ground it to your batterie's negative terminal, see what happens?
      @IRON-E30 aka Edwin:D
