PNW: Need some Electrical work done?
  • StereoInstaller1
    GAS
    • 22679
    You guys all know I do car audio installation stuff, alarms and remote starts and all that too...but I would like to do a bit more electrical repair.
    If you need a project completed, major or minor issues solved, hit me up.
    Anything from "un-hacking" a lame 24V swap harness that has the check engine light installed under the hood to auxillary fan wiring, whatever. Race car stuff too, fire suppression systems, custom panels, Driver Cooling systems, literally anything.
    I hope my reputation speaks for itself about the quality of my work, and you guys all know how important my reputation is to me. You know you will get the best quality I can give you within your budget, all the way to Concours level.
    I am very well equipped and can move things around in my schedule to fit your needs. I can and will do mobile work (no big stereo jobs mobile, unless I have a full shop at my disposal) but be prepared to pay extra for travel time.
    You can find me here via PM, or add "@gmail.com" to my username, or use the FB link below.
    Thanks!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
  • StereoInstaller1
    GAS
    • 22679
    Gotta keep this on top. I need some work!
    Closing SOON!
    • KenC
      King of Kegstands
      • 14396
      I don't have a picture right now, but Luke made us a fully loaded subwoofer box for our outdoor speaker system. Two 12" woofers in a sealed and fully weatherized. Met all expectations!
      He offers a diverse array of services.
      Originally posted by Gruelius
      • CabrioPunk
        • 1451
        How about one touch window switch kits, drop-in ready?
        • StereoInstaller1
          GAS
          • 22679
          No, no thanks. Looking for some LOCAL work. I need to keep my work diverse or I get stagnant. I fart dust as it is, I cannot let it get worse.
          Closing SOON!
          • Wishno87
            • 6025
            The 24v car im building right now has a fairly integrated Clifford system that I feel may cause problems. If I need it all removed I will let you know.
            • jrobie79
              • Mar 2006
              • 2526
              if you're ever in New England I'd like some professional help tuning my system, I have no patience for it and want it to sound pretty good from someone else, then I can make minor tweaks to my liking, but I dont have time to get the whole thing sorted out
              1991 318i ---- 308K - retired
              • StereoInstaller1
                GAS
                • 22679
                Dude, that is like a 20 minute job you can handle yourself. If you get stuck, just give me a call. If you want, I can hit you up next time I am in the 'couv, should be a week or three.
                Closing SOON!
                • bmwm42
                  • 6300
                  I want to run two stock aux fans could you help with that
                  Originally posted by bmwm42
                  PNW vulture pm me for parts
                  Strategic nw e30 command
                  • KenC
                    King of Kegstands
                    • 14396
                    Go with the later curved-blade ones.
                    • StereoInstaller1
                      GAS
                      • 22679
                      I just mounted a stock AUX fan on custom brackets for Erik on the early black S50 car, with no A/C condenser. I used aluminum strips to make brackets which bolted in and use the fan's stock rubber anti-vibration mounts.
                      We decided to jumper the A/C switch to high speed as a controller, as the shitty wiring on the motor install had the switch wiring unfinished, and we did not have time or budget to fix the fan switch properly...plus the damn switch is bad anyway.
                      So his stock AUX fan directly on the radiator has been flawless so far. He gets in heavy traffic and just turns it on, no worries. I think I charged him $100 or so, total.
                      And yes, it was a later curved one.
                      Luke
                      Closing SOON!
                      • bmwm42
                        • 6300
                        I have later curved ones now one that for my AC and the other replacing the stock cluth style. I mounted it to the fan shroud but can only run one at time I'd like the other connected to a toggle switch for when I'm in heavy traffic to have no problem keeping the car and my AC cold.
                        • StereoInstaller1
                          GAS
                          • 22679
                          No worries! I will be in PDX roughly the 10th, got a huge party the 8th in Springtucky.
                          Closing SOON!
                          • Balleristic31
                            • Aug 2009
                            • 4198
                            Sent u a pm luke
                            -NICK
                            • Wishno87
                              • 6025
                              Its like a cancer though. Its in every nook and cranny and I dont know where the system ends and the car starts. I will probably be hitting you up about a full E30 stereo system sometime this winter though. A car we bought for my sister has one of your systems and it sounds amazing.
