My amp, PPI PC450, suddenly won't turn on.
When I turn on the HU, it turns on for like half second and shuts off and it repeats every five seconds or so. Everytime it turns on for quick second, green light comes on and the speakers make slight popping noise.
Here's things I did to better understand the situation.
I installed this amp and a HU w/ stock wires and the speakers are PS.
After the install I was impressed with the improvement of the sounds.
I listened to it for about five minutes and I turned up the front gain a little, since I wasn't getting any distortion w/ the volume all the way up.
I didn't have much time so I left it as is and came back to it about 4 hours later. Car did not move and everything was exactly same as I left it.
Before I started the car I slightly turned up the front gain again, because I still did not hear any distortion on my previous adjustment.
When I started the car, I felt like I'm not getting the bass like it did earlier.
And for some reason it did not sound good to my ears, even though I was playing the same song I did earlier.
So I went back to the amp and turned down the gain all the way to start over and when I checked the sounds it still sounded funny.
Suddenly sounds got very distorted and dimmer and then no more sounds, but popping every 5 seconds.
When I went back to the trunk, I've learned that the amp is keep shutting off.
I bought the amp used and I know it's an old amp back from 90's.
But I want to know if it's the amp causing the trouble or something else.
Power is coming from front battery with 4 gauage wires and the ground is connected to the back of the trunk with the paints scraped off.
Remote wires are the stock remote and the antenna twisted together into the HU's Blu/wht cable.
Any ideas? and pls teach me the easy way to trouble shoot where the problem is coming from.
Thank you in advance.
