Well, Ive got a strange one.
I was testing the wires that hookup to the Ashtray Lighter and illumination (I think there is a light in the ashtray?)
In any case I used my meter to determine that there was 12 volts on one connector and then checked it by using the Red/Yellow wire as I thought it might be a source of ground. Nope. The Brown wire next to it was Ground. All was well or so I thought.
Then I started the vehicle and pulled the light switch all the way out. The light for my on board computer turned off and my cluster lights did not turn on.
I pushed the Light switch to the off position and found that the On Board Computer light turned ON ! WTF?
I figured it was a fuse. Pulled EVERY fuse out of the panel and checked each one by one for continuity between the spades. Each one DID HAVE continuity. Put them all back in their respective places.
Grabbed my Bently Manual to see if I could track the issue down.
On page 24 of the Electrical System section it indicates that I should pull the cluster and check certain pins on the connector that goes to the Cluster.
Anyone have this issue before and have any insight?
