alternator
  • TG Goose
    • Jul 2011
    • 234
    alternator
    On an 84 318i, can I run the 90 amp alternator from a 1990 325i? They physically look the same.
    Or, what is the best swap alternator for an early m10 318i?
    ______________________________________
    1984 LSB 318i - Sold
    1986 325i - Motor Swapped Track Car Project
    1995 318ti - Sold
    1999 540iA - Daily Driver
  • Ceeker
    • Sep 2009
    • 2821
    find out what amp it is. and match it.
    • bmwguy325is
      • May 2011
      • 1263
      Id say you are ok to do so. Its still only going to put out 14.4 but you can run more stuff like ICE or a welder. It may bog the car down at idle a lil
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • TG Goose
        • Jul 2011
        • 234
        1984 318i alternator is 80 amp
        1990 325i alternator is 90 amp.
        physically they look identical, mounts, connections are in the exact same location.
        I was just wondering if anyone had ever done this swap, or if there is a better alternator swap to get more amps. I'm putting in a decent system and 80 amps seems like a little on the small side.
        1995 318ti - Sold
        • 84driver
          • Aug 2011
          • 234
          Hmm I was wondering this exact same thing. My alternator has seen better days and I want to replace it with the best option. I will subscribe to this newsletter.
          balticblau-metallic '84 318i 5spd 3.91 LSD
          • DRTSRFR
            • May 2008
            • 1836
            It won't hurt a thing. It'll simply have the capacity to handle a higher load.
            I've been swapping alternators for years. I'm running an alternator from a fully loaded lincoln continental on my '73 Bronco for the added output.
            Suspension tips here...
            http://www.r3vlimited.com/board/album.php?albumid=757
