Alternator Whine
    Alternator Whine
    As the title states I turn on my car one morning and this high pitched buzzing is coming from the stereo speakers. After googling I find out that it is indeed alternator whine. Also sometimes when I press the breaks in accessory mode or use the foglights or highbeams while driving, the Stereo Deck either shuts off or restarts. I looked behind the stereo deck and everything seemed to be in order. So for the past 2 days I've been driving with the radio off to prevent myself from throwing it out the window. Any idea on what to do?
    Im curious if they ran you a new ground and goes to the same spot all that other stuff dose. There are two bolt(may be wrong) that ground under the steering wheel. maybe it has vibrated loose.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      I had a whine in my system because it was ground with the same bolt as the ECU. I think it was picking up the injector pulses...
        Alright, I had a look at the wires and there is no other ground I don't think, but it looks like there is 3 brown wires spliced into one wire that connect to the head unit. I've bought a couple inline filters too, I'll see if that does anything.
          Might need to replace the alt, a bad diode can cause a whine. Alsp clean off your connections at the battery, bad connections will cause increased resistancce,resulting in a whine.
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            Just thought I would update this thread, my battery ground wire was beginning to get corroded so I replaced it with a 10$ Canadian Tire battery ground cable and not only did it fix my alternator whine it also fixed various other electrical issues and increased my Idle speed from 650-700 to 1000 rpm. I would recommend changing it if it hasn't been changed already.
