I know this is my first post and yes, I've done extensive research with no luck in finding a solution…this is also my first E30 which I just purchased Monday.
I purchased a Pioneer head unit from crutch field. It recommended some kind of cross over module when purchasing the unit because it has premium sound. It's called a PAC SOEM-4 and should allow me to keep the factory amplifier.
I pulled the factory tape deck out and there is a blue and yellow wire. One for the right channel, one for the left channel. Each wire has two prongs. When I purchased the head unit, it came with an adapter to split these into a Gray and Gray/Black as well as a White and White/Black for Left Front +/- and Right Front +/-.
I hooked everything up per instructions on the SOEM-4 and the unit powers up, but no sound.
From the research I've done, I seem to see examples of e30's with factory twisted wires to the factory head unit which doesn't seem to be present here.
I don't want to hack the factory harness at all possible and am asking for help from the group. What am I missing here?
Here is a link to some pictures of what I've hooked up thus far.
Thank you all for any help you can provide!
All the best,
AJ
All the best,
AJ
