So after reading so many different things about sound deadening/dampening products I realized two things:
1) If you truly want to make a huge difference in your car's environment, get professional studio quality sound dampening/deadening, it'll do five times a better job then brand name car sound dampening/deadening for the same price or cheaper.
2) It's going to be expensive as hell to do it properly no matter what route you take.
So I'm going to do it my style. Walmart/online has memory foam mattress pads in an array of thicknesses for very cheap, like 20$ for a full.
So instead of buying expensive brand name stuff I'm going to use memory foam.
My question is what areas are prone to rattling, vibration or some type of noise making?
I'm going to cut up the foam and use it to dampen those areas the same as normal product would be used. I will also use it as speaker baffles, and probably do a layer across the entire floor under the carpet.
Any ideas/suggestions would be appreciated thanks!
