Sub magically stopped working
  • jaywood
    • Jul 2010
    • 4528
    I was driving to school this morning, plugged in my iPhone (via USB to headunit) to play music like I do everyday...but today was different. There was no bass!
    Everything was working fine yesterday, so what could have happened? I didn't change any of the HU settings.
  • steinbachphoto
    • Aug 2007
    • 914
    did you check if the power cable or ground maybe unplugged from your amp? Stranded cable has a tendency to slowly break away from the typical amp screw connector. Maybe the RCA's? if they are plugged in then get a DMM and see if there's voltage coming through the cables.
    http://www.steinbachphoto.ca
    • jaywood
      • Jul 2010
      • 4528
      I didn't have time to check much this morning. I will check it out after school. I just want to know what to look for!
      • bmwguy325is
        • May 2011
        • 1263
        I'd say you listened o loud and blew it. However.... If it magically stopped working I say get som lucky charms a few Harry potter books and a magic wand from the dollar store... Should fix it
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • jaywood
          • Jul 2010
          • 4528
          How could I have blown it? I play it at the same volume everyday.
          Can I test if it's blown? The woofer isn't moving at all when I play music
          Maybe it's my iPhone cable...I'll try a cd because I have no radio :(
          • StereoInstaller1
            GAS
            • 22679
            What all is in your setup?
            Closing SOON!
            Thanks for 10 years of fun!
            • xwill112x
              • Jan 2009
              • 4236
              Check your power connections
              • StereoInstaller1
                GAS
                • 22679
                You do know if you don't get the plug all the way in on your phone you get no bass, right? I assume everyone who uses a miniplug knows about that
                Closing SOON!
                • jaywood
                  • Jul 2010
                  • 4528
                  Polk sub, kenwood amp, pioneer HU
                  It's been working fine for over a year now...maybe something got loose.
                  And yes, it was plugged all the way in ;)
                  • jaywood
                    • Jul 2010
                    • 4528
                    Well, I plugged my phone in after school and it worked. It doesn't sound the same though.
                    Deep bass sounds the same
                    Higher bass.....there seems to be a rattle inside of the box. Maybe part of the sub? I'm not sure.
                    • ethirtydavid
                      • Jan 2008
                      • 2331
                      I can fix it ..
                      • ethirtydavid
                        • Jan 2008
                        • 2331
