Window issues
  • luis.e30325es
    • Feb 2011
    • 128
    Window issues
    Hopefully someone on here has info and experience with e30 window problems.
    i have an 86 325es if it matters
    my windows stopped working a while ago. i took out the regulator and cleaned out the motor. but still wont go up or down with the window switches, circuit breaker is good, i jumped it to verify but still nothing, i jumped the switch connectors themselves, but nothing. anyone?
  • StereoInstaller1
    GAS
    • 22679
    Have you tried using a meter to check voltage at the motor plug?
    Closing SOON!
    Thanks for 10 years of fun!
    • luis.e30325es
      • Feb 2011
      • 128
      Im going to try that tomorrow. is the black wire the ground and blue the positive?
      • TurboJake
        • 3780
        Yes. But black is also positive and blue is also ground.
        (It depends which direction you're energizing the window motor)
        Leave Me Transaction Feedback
        • luis.e30325es
          • Feb 2011
          • 128
          Problem fixed, today as i was leaving my house i decided to mess with the door plug to the door frame. and all of a sudden my window goes down! i unplugged it and noticed a lot of corrosion and green build up, tried to clean it up, but it was pretty difficult. so i decided to avoid future issue and just by pass it by going around it. so now my windows work, except they are a little weak due to black sludge/ grease build up inside of them.
