Fuel gauge not working
    I have a '88 325ic that the fuel guage is acting up. My mechanic check all the connections and voltage and everything seems right.
    What could cause this, gauge went bad? If so, I saw on ebay a fuel gauge but its Motometer but my cluster is VDO, is it the same connection?
    Here's a vid I made yesterday.
    Thanks in advance.
    tighten the nut on the back?
    Continuous For Sale Thread
    323i s50
      Ive checked this morning and its fully tighten
        I have the same problemo
        Any body ever fix there's ?
          hahaha that's crazy. sorry but i can't help, hope it's an easy fix
            I just took out my sender, took the tiny nut off the bottom, removed the aluminum cylinder and used 3000 grit sand paper to sand the tiny wires inside that the float slides on. Fixed it right up. Works perfectly now.
            Originally posted by Andy.B
            I was born on 3/25…
