My 87 325is displays the oil and brake light circuit as problematic. However everything is operating as normal, oil is as full as safely possible. Both lights came on simultaneously. I am curious if anyone has a schematic for this circuitry or any bright ideas where to start. Let me know if any further info that would be helpful.
Warning Panel wiring schematic
Got one, give me a minute: http://wedophones.com/Manuals/BMW/19...g%20Manual.pdfLast edited by cabriodster87; 02-14-2012, 07:59 AM.sigpic
Reich und Roll! -
If you are referring to the brake lining light, this is a known problem/fix. There is a resistor on the cluster circuit board that needs to be soldered.
If search does not turn up solution with pictures. I will look through my stuff and see if I can find it for you. Let me know.Comment
