My check light comes on under this weird circumstance: wipers on speed 1 and when the brake switch is activated...so when i tap or press the brake pedal while its raining w/ wipers on spd 1...and only if its raining. If i go to speed 2 or 3 with the wipers i dont get the check light at all. But with speed 1 it seems like a constant current. Sometimes (rarely) the check light will come on with the wipers on spd 1 without braking. I'll hear a little static noise in the speakers and then see the check light. Even with the head unit off it happens in that cycle.
I was thinking maybe i should replace the tail light gaskets and the front top seal to protect both the check panel and tail lights. My antenna gasket is a yr old so that shouldnt be a problem. Any ideas other than that? It seems like some contact is getting penetrated by rain that is connected to whatever wire current the radio/wipers/brake light are on. I dont know a whole lot about the wiring in these so any help is greatly appreciated.
