splicing antena cable
  • long tall eta
    • Jul 2010
    • 1536
    guys, just picked up an oem antena for a friend of mine (chick) but the junk she has in there now is jimmie rigged and the original conector from the wire that plugs into the antena has been cut and make shifted to go into the junk she has now. where can i get the conector to splice back in to the cable or do i have to but the entire cable.
  • bmwguy325is
    • May 2011
    • 1263
    For best results but a new cable.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • accident
      • 7303
      definitely but the cable.
      Moral of this story?
      • long tall eta
        • Jul 2010
        • 1536
        how/where does the cable run to the head unit? will i have to pull up the carpet?
        • accident
          • 7303
          Right over your head.
          But yes, if I recall correctly the antenna wire does run under the carpet. If you pull off your back seat you should be able to see the path it follows.
          • long tall eta
            • Jul 2010
            • 1536
            so, how much better of a signal would it be between a new cable and just splicing in a new conector to the existing cable. this is charity work for a friend and i have enough shit to do on my own to get to involved with this.
            • accident
              • 7303
              If it isn't your car, and you're doing it for free, ghetto rig that shit so that it works. ;)
              • Quadrajet
                • Jul 2008
                • 1278
                I'd stop in your local Radio Shack, for starters, they may have repair stuff for that.
                • Morrison
                  • 430
                  I just went through various antennas and wiring combinations looking for good radio signal. I first tried a Z3 antenna base with stock z3 antenna, and new factory cable (for z3). I had dick for reception from this combo, but believe the amplified antenna base must have been junk.
                  What I arrived at that has given me even better reception than in my X5 (which is actually pretty good) is the following:
                  3 section manual telescoping antenna from Autozone - $20
                  ~8 feet of RG6 home cable wire to combine with 4 ft that comes with ant.
                  Then splice as necessary via soldering the inner conductors together and also the outside shield but keep them separated. Route wire through and under center console area for shortest path.
                  "I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
                  -Franklin D. Roosevelt
                  • MaksV
                    • 1042
                    its coax so its pretty hard to splice.
                    CHEAP REBUILT INJECTORS
                    Need Quality Brakes? BimmerBrakes has it!
                    For anything Else go with BluntTech!
