91 318is
  • 'e30love'
    • 893
    91 318is
    hey guys im a little stumped at the moment on this, today i decide to wite up my fogs, everything went gravy, previous owner had an alarm installed and as i proceeded to remove it i got stuck on this relay.
    the op had it spliced with some wires i meed to figure out what are my options, i disconnected it and car wont start, when connected it starts. but i have a wild theory that he used that relay as part of the alarm drawing power from other cables. i ran the part number on real oem and nothing came up. does anybody know what that relay is for?
    also to kill two birds with one stone id like to remove evrything airbag oriented while im in there.
    can that and everything else that is orange go? what else am
    i missing to completely remove it?
    the shitty alarm for refrence
    im trying to clean up under there. all help is appreciated r3v.
  • AndrewBird
    The Mad Scientist
    • 11898
    The relay was likely for an ignition disable feature. You will have to figure out what wires that are stock run to it and return them to their factory configuration. Likely be as simple as splicing one wire back together.
    • 'e30love'
      • 893
      thats what i figured tommorrow ill remove the relay and connect the wires as they should have been. anything on airbagstuff?
      • 'e30love'
        • 893
        if i were to remove the entire airbag srs system would this have to go as well?
        update: i removed the module and fished out all cables relating to srs even the sensors in the engine bay,
        also figured out relay prbloem just removed it and color matched wires everything works like a charm.
        thanks r3v
