Where does MPG needle supposed to be when the car is in idle?
  • IS300E30
    • Apr 2009
    • 408
    When the car is on and I am parked. Does the MPG needle (right below the RPM gauge) supposed to be resting at the "40" number or the "0" number?
  • bimmerteck
    • 762
    • DRTSRFR
      • May 2008
      • 1836
      Correct, if you aren't moving, you're getting 0 miles per gallon.
      Suspension tips here...
      http://www.r3vlimited.com/board/album.php?albumid=757
      • IS300E30
        • Apr 2009
        • 408
        I thought so. Just wanted to make sure. Thank you both for your help.
        • redsubdivisions
          • Feb 2011
          • 1762
          You should be getting 1,497,330,224 miles to the gallon at idle, give or take a few here.
          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
          2012 Passat TDI - DD Duty
          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
