Windshield wipers gone full retard (video)
  • lambo
    Captain Scene Points
    • 10953
    So, I've had this issue for a while. When in the first wiper setting, the wipers seem to freak out when they are coming back down and the regulator makes this weird noise. However, they work perfectly fine in all other modes....just not the slowest one...
    Here's a video:
    Thanks!
  • bmwguy325is
    • May 2011
    • 1263
    You need to replace the big black box in the fuse box. Its the wiper control relay. Also adjust the driver wiper so it wont bottom out.
    What the noise is is the relay clicking over.
    Be lucky it dosnt stick on. Had that happen before.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • pandaboo911
      • 2070
      The nuts holding them on are loose? the noise is probably from the little splined stub rotating inside the wiper arm
      • lambo
        • 10953
        Tried that, I get the same noise...and the wipers worked on the car I took it off.
        The noise is coming from the regulator, I can feel it vibrating when it's making the noise...
        • lambo
          • 10953
          Also, I should mention that after a while they start working normally.
          • bmwguy325is
            • May 2011
            • 1263
            Check the wires for lose connections. The noise is the relay switching on and off super fast.
            • lambo
              • 10953
              This is after letting them run for a couple minutes...
              Edit: After taking that video it has stopped making noise...wtf?!
              • lambo
                • 10953
                Should I check near the wiper stalk on the steering column?
