Sooo I'm at the gas station and my wideband gauge reads voltage error and then my wiring harness starts smoking, I quickly shut down and it stops. I check my wiring thinking its a wideband issue but its not; it was coming from the ECU harness I turn the car on one more time and then wire melts through the black wrap and is glowing bright red. I shut off the car and examine the wire. It has NO more insulation on it but from what i could find there was A blue/green wire insulation sitting near it so I'm guessing it was that color. I cut the wire because it was already dead and I needed to get home, I cut the wire and all is well now........
Problem is that the car still runs perfect and everything appears to work...... what was the blue green wire at the harness?
