Central locking gremlin. New control module?
  • quikveedb2
    • Sep 2007
    • 2258
    A couple days ago my central locking started acting up; upon locking the car from either door, or the trunk the doors will unlock immediately after locking with no action from the key. If I lock from the trunk, it will stay locked, but the doors will still unlock themselves. I'm thinking it's new control module, or maybe something else, hell idk, it was working fine until it sat for 2 days. Thoughts? Tia.
    You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
  • quikveedb2
    • Sep 2007
    • 2258
    Bump.
    • quikveedb2
      • Sep 2007
      • 2258
      100 views, no ideas bump.
      • lbreevesii
        • Aug 2009
        • 412
        I don't always wreck cars, but when I do I wreck them into trees.
        91' 318is S50 swap - The Black Widow
        • fporro
          • 1859
          - open driver side door
          - undo harness connector at pillar
          - check connector, clean off corrotion as needed.
          if problem persists then follow this instructions ... http://www.bimmerboard.com/forums/posts/48131
          cheerios,
          Frank
          • quikveedb2
            • Sep 2007
            • 2258
            Thanks guys, can you point me towards a source for the pins for the c404 connector? I definitely have some corrosion going on in there & I suspect it might be the source of my central locking problems & flickering dome lights.
            • fdourado
              • May 2012
              • 81
              I had a similar issue. For me it was the trunk actuator. Replaced it and it worked fine, so I would suggest checking those out.
              -Filipe
