Box in Trunk
  • PeaveyBassist
    • Sep 2004
    • 3511
    Box in Trunk
    My box will be on the driver's side right up by the wheel well. I was going to bolt it down so it doesnt move. Is there anything directly under the floor that its possible to hit? I wont be able to look under the car until Saturday. Also, what kind of bolt to use? I figure a screw wouldnt work lol so what type of bolt?
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • Mastrcruse
    • Sep 2005
    • 5340
    My brother put 12's in with box and he had no problem with movement. Just keep the carpet in and make sure that the box is wrapped in felt that you usually see them have and it won't slip.
    • PeaveyBassist
      • Sep 2004
      • 3511
      My box is only for one 8. Base will only be about 6.5" x 12" or so. I drive quickly so I want to bolt it down. I use to have a bigger box and never had problems with movement but I'm not takin any chances with this one.
      Will
      DaveCN = Old Man
      • StereoInstaller1
        GAS
        • 22679
        Will, pull your seat back out and run screws into the box through the sheet metal.
        Highly theft resistant, I promise.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • PeaveyBassist
          • Sep 2004
          • 3511
          Sheet metal screws correct?
          Will
          DaveCN = Old Man
          • Jordan
            • 12913
            nah, use some agressive bit wood lag screws.
            Thats what I did, and like Luke said... very theft resistant.
            My amps were also bolted through the box, with the hardware on the INSIDE.
            Stealing any of it would have been a serious PITA.
            https://mtechniqueabs.com/
            • PeaveyBassist
              • Sep 2004
              • 3511
              So pre drill the box and metal then shoot the screw on through it? I know I sound like a noob lol I just awnna make sure I'm doin it right.
              Will
              DaveCN = Old Man
              • Nathan
                • Apr 2004
                • 671
                No need to pre-drill. Pre-drilling is only required for material that is likely to split or the size of the screw would make it to difficult to drill. A high powered drill and some drywall or similarly agressive screws is/are exactly what you need. The sheet metal behind the rear seat is very thin and the screw should just bite into the metal and then pull the box tight.
                PNW E30 CREW ///
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  Alrighty. Sweet. Thanks guys.
                  Will
                  DaveCN = Old Man
                  • !RocknE30!
                    • Sep 2004
                    • 475
                    Good info, I'm probablly going to be putting two 12" subs with an Orion amp into my car after I buy a Viper alarm system.
                    Glad to hear of some more anti-theft techniques. My personal favorite, which I thought of, was to find a few rattle snakes and stick one or two in the glovebox and 6 or 7 in the back. You can bet no one's stealings hit out of my car and if they do they won't get far once the venom kicks in ;)
                    91 318is | 98 Z3 M Roadster | 97 FZJ80
                    • rwh11385
                      lance_entities
                      • 18403
                      SO THE WILL WILL BE GETTING THE BUMPS?!??!??! omg 1111elevent!!!sauce
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        lol naw. Just a small 8" one. TINY box. 0.3 cubic feet sealed. I dont need no bumpidy bumpidy kill my hearing bumps all the time. Just something to reinforce the low end. Next thing to work on is my midbass. It is t3h suck. :(
                        Will
                        DaveCN = Old Man
