no spark issues---update 9/2 still need help
  • dustyperez
    • Feb 2012
    • 390
    ok guys so i refreshed my whole engine. and now i seem to have no spark. cap, rotor, wires plugs are all new. the coil is NOT new but i had it tested and it throws spark. i tested all the parts for proper ohm readings and they all checked out. including the cps. i have proper volts at the coil as well. however if i take a spark plug out and ground it to check for spark i get nothing. I did do a 5 speed swap as well and did the old wire splices under the dash like a write up said. is it possible i wired something wrong and the motronic is telling it not to spark???
    i have heard of the fusible link in the trunk but would i have power at the coil if that was bad?
  • dustyperez
    • Feb 2012
    • 390
    ok so i checked all the components and the fuse link in the trunk. all seems good. but i have 0 spark coming out of the coil. i do have power to the coil and it checked out to 4000 ohms.. the bentley says 5000 so could this be the problems? MY main question is what does the black wire from number 1 on the coil go to and is there any way to test it?? maybe its not getting signal from somewhere?? thanks guys
