So my amp is toast....
  • nparente
    • Jul 2012
    • 50
    What are my options. I have a 91 IX with premium sound. Can i just bypass the amp with the stock headunit, or do I need to upgrade to an aftermarket head unit?
    Thanks
  • kmarei
    • Apr 2008
    • 194
    Hw much do you want for the amp?
    • nparente
      • Jul 2012
      • 50
      Anybody?
      • 416stroker
        • May 2008
        • 2448
        LOOK at the sticky "Radio Wiring and Amp Bypass" for wireing.
        And you may be able to use the stock unit. im not 100% positive
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • dogsbark26
          • Nov 2008
          • 533
          Which head unit do you have? I'd replace the amp before I'd replace the head unit.
          • nparente
            • Jul 2012
            • 50
            I have the stock HU, no fader (http://www.webstore.com/thumbnail.ph...w=500&sq=Y&b=Y)
            I guess my question really is, can the stock HU work w/o an amp and not sound like shit?
            Thanks,
            • UNHCLL
              • 8789
              A replacement factory amp, used, shouldn't cost more than $25-30.
              The headunit won't work work without an amp... it's not strong enough.
              Do you know how to access the amp in the car?
              Below the radar...
              • nparente
                • Jul 2012
                • 50
                I know how to access it, any ideas on where i can find an amp for cheap? I cant seem to find one for less than 50-60. At that price, i might as well spend 100 on a new head unit, bypass the amp, and get ipod/bluetooth, right?
                • UNHCLL
                  • 8789
                  If you can check the PN/Model number on the amp, I can see if I have an extra in storage.
                  But yes, for close to $100 you can get a modern headunit and just splice a few wires and be done.
                  That might be the way I'd go if you were already considering it.
                  -Chris
                  Below the radar...
                  • nparente
                    • Jul 2012
                    • 50
                    -Chris
                    RealOEM says that it's 65121375983. If I have time tomorrow ill pull the amp and double check it.
                    • AndrewBird
                      The Mad Scientist
                      • 11892
                      I would check the local scrap yard. Should be able to get one cheap at a U-pull-it.
                      • hotrodlincoln
                        • 413
                        I think I have an amp for ya. $30 shipped if you are in the lower 48.
                        • nparente
                          • Jul 2012
                          • 50
                          I'll PM you when I pull my amp out.
