clipped wires help
  • ///digitalme
    • Dec 2009
    • 2088
    clipped wires help
    theres 2 wires clipped under the back seat by the fuel pump....
    if i connect them i start blowing fuse number 21 i believe it is, for the cluster lights and stereo....but if i plug it my fuel gauge works..want to find out what they are so i can trade where its shorting i believe its the radio the po installed...
  • AndrewBird
    The Mad Scientist
    • 11892
    ETK can be found here:
    Download the correct one for your car and start looking for wire colors.
    I can tell you the brown one is a ground as all brown wires on an e30 are ground. The other is likely power if you connected them and blew fuses. I would recommend NOT doing that again.
