Whining sound when radio is on?
  • Pocket Chant
    • Mar 2012
    • 403
    So, I have an aftermarket radio in my E30. I noticed the other night that there is a slight whine when it's on, and it increases with the RPM. (It's not the antenna either, but it sounds similar.) I figure it's a Ground, but just wondering if anyone would know which one in particular.
    Thanks!
    1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
    MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
    Originally posted by MclubSport
    Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
    Horrible with responding to PMs, I'm so sorry.
  • randomtask37
    • 3154
    from what ive heard when the whine increases with RPMs it has something to do with the alternator. either it is going bad... or maybe the alternator ground is bad. I dont know for sure, but this is what ive heard.
    98 M3/4/5
    • dwvw
      • Sep 2011
      • 234
      All alternators produce that sound, and the more output it has the more of that sound it will put out. Your first line of defence against it, is a good battery. The battery filters the noise best when it is in good shape. If your battery is more than 4 years old, replacing it is usually a good idea.
      Do you have an amp in the car as well? Alternator whine is usually caused by a ground loop, which is a difference in potential between two or more grounds in the same chain of components.
      • Pocket Chant
        • Mar 2012
        • 403
        Alright, so I think the problem is in the HU wiring. I went into the back and relocated the Amp ground, that didn't do anything, tried unplugging the RCAs on both ends, no good. Then when I pulled out the HU to get to the RCAs, the noise got louder. I fiddled around with the wiring going into it, and it made even more noise, then almost none. I'm tracking down the particular wire now.
        • LJ851
          • 7918
          My car did the same, removed the factory amp and it went away.
          Lorin
          The M30 is God's engine.
          • bigdaddy325ic
            • Oct 2012
            • 15
            Bad ground !!!!!!!!!!
            Thanks!
