Coupe no ski pass how to get bass in the cabin
  • cluna
    • Sep 2012
    • 32
    So I have a 84 coupe with 2 Jl 12's but no ski pass so getting little bass in to the cabin is there anything I can do to get more bass in my cabin ??
  • Cabriolet
    • 9620
    get an 86
    Much wow
    I hate 4 doors
    • FLG
      • Sep 2011
      • 3165
      Excuse my ignorance but does it have the template for the ski pass cutout? My seats had no ski pass but the template behind the seat was there and just needed to be knocked out
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • kmarei
        • Apr 2008
        • 194
        I don't have a ski pass on my M3
        I have a sealed 10" sub in the trunk
        Drivers side, facing the back of the car
        Sounds great
        300w rms
        • Cabriolet
          • 9620
          very early cars dont even have that template
          Much wow
          I hate 4 doors
          • bmwguy325is
            • May 2011
            • 1262
            Sawzall and or hole saw.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • cluna
              • Sep 2012
              • 32
              Yeah I was thinking about cutting but I would need the strength up
              • StereoInstaller1
                GAS
                • 22679
                Yes. Easy answer, buy and install one of my boxes!
                So yeah, you need to cut a hole (carefully!) but I can help you with that.
                Your pair of 12's will still sound shitty, the E30 is a well-known "bass trap" and is one of the main reasons I design my boxes to work the way they do. Typical thinking of "throw a box in the trunk" just can't make good sound in these cars. The shit that works on a Honda just does not apply here!
                You may not believe this, but one of my 10" boxes will kick the shit out of the pair of 12's you have now, and the 12" are absolutely brutal.
                Getting the bass into an E30 (or any other really well-made car) is tough. We build our boxes to "force" all of the bass into the cabin. We use a foam gasket over the seal area just to make sure it is a 100% seal. Our 10" boxes use the ski pass hole for the ports and the woofer, like this:
                Our 12" boxes use holes in the rear deck for the ports. The port tubes actually fit into the box, again, forcing ALL of the bass into the cabin:
                Here you can see the foam gasket and how it seals. We recommend using 4 screws to hold it in place. They are visible in the 10" pic.
                Our boxes come fully upholstered so the foam is not visible. There are lots of pics on our website. This is one of our 12" e30 boxes, fully upholstered in gray.
                We also make 8" and 15" boxes for the E30, along with our beautiful amp racks
                The beauty of these is in the performance you get, but not just big stupid boom, but deep, clean, clear articulate bass that is much louder than normally expected. The efficiency of the design allows smaller woofer to perform incredibly well, typically we expect to see over 125db under 35Hz with only 200 watts from our 10" box. Our 12" boxes have done over 140db with as little as 300 watts!
                We get a lot of people saying "wait, that is ONE twelve?" Even better to me are guys that had a pair of 12" in a sealed box, then go to a single 10" G.A.S. box. They all say the same thing: louder, cleaner, clearer, deeper and better wound quality than any of their buddies, for 1/2 the cost.
                Another wonderful benefit of our design is NO RATTLES! Seriously, it is just bizarre. Big loud BOOM when the windows are down, outside the car...but virtually no rattles inside or out.
                Oh yeah, you get to have LOTS of big fat boom, but you keep most of the trunk space too.
                Sounds great
                300w rms
                Yes, you do. All M3s have the ski pass cutout, that has been proven many times. Pull the cardboard from your trunk or pull your back seat, you will see the cutout, then you simply whack it with a hammer:
                If you switched to one of our designs, you would have cleaner, clearer, tighter more articulate bass, more trunk space and WAY more SPL. In fact, if you are using the typical car stereo shop sealed 10" cube, our 8" will easily outperform it with half the power.
                We have sold over 600 subwoofer boxes on this site alone, the performance is well documented.
                Let me know if I can help!
                Luke
                Closing SOON!
                Thanks for 10 years of fun!
                • kmarei
                  • Apr 2008
                  • 194
                  Luke
                  My 10" box is like half the size of yours :)
                  Plus I'm not really a fan of ported boxes
                  Do you make any that are sealed?
                  Too bad you're on the other side of the country
                  Would have loved to do a direct comparison between both boxes with the same sub and amp
                  Too long a drive though :)
                  • StereoInstaller1
                    GAS
                    • 22679
                    Sealed? Nope. I find sealed boxes flat, boring, slow and sloppy. Very rarely do I find a sealed box I would want to listen to...but, I hear what you are saying, I would agree that most ported boxes sound like shit. Mine "couple" fantastically with the interior of the cabin, and they are designed to work with the acoustical issues of the E30. My boxes are an audiophile thing, not your typical "car stereo" bullshit bass, so not at all what you expect from a vented box. They really do make tight, clean, articulate bass that is seriously fun to listen to.
                    As far as hearing one, I have shipped a couple dozen to your neck of the woods, I am sure we can find someone fairly near you so you can compare. We have shipped well over 600 boxes out, there has to be someone nearby, right?
                    Luke
                    Closing SOON!
                    • cluna
                      • Sep 2012
                      • 32
                      That's looks great u have seen your boxes they look amazing do you make 12 in box and how would I go about cutting the back
                      • StereoInstaller1
                        GAS
                        • 22679
                        Well, we have a couple options, but it would be best if you could post a pic of the trunk wall. There are actually 3 different early trunk styles, and I can make a box specific to your application.
                        Last one I cut out (I have done a few) I used Snap-On "aviation style" tin snips, but I have used jig saws, air saws (pneumatic body saws) and "nibblers" (NOT recommended!)
                        If you do one of my 12" boxes, you will need a 3.5" hole saw too.
                        Luke
                        Closing SOON!
                        • Steve Corbett
                          • Jul 2012
                          • 449
                          Here is a picture of my 1984 with NO skipass cutout, Build date of Nov 84. His might be the same. Is there a template we could use? Do we need to reinforce what we cut out? Help!
                          Steve Corbett
                          1983 528E Scrapped
                          1983 528E Sold
                          1984 745I
                          1984 325E - Sold
                          1989 325I Bronzit-Sold
                          1989 325I Zinno
                          1988 635CSI
                          • cluna
                            • Sep 2012
                            • 32
                            Mines also a 84 and the same as that
                            • StereoInstaller1
                              GAS
                              • 22679
                              Guys, both of you can use our standard 10" or 12" boxes...kinda cool, they are cheaper than a custom job.
                              You will want to basically cut the hole as if it were a ski pass, so see if you can get a close look at a buddies trunk.
                              If you are not confidant about it, we will find a solution.
                              Thanks!
                              Luke
                              Closing SOON!
