Fuel gauge, tach, and temp gauge all died
  • Y30
    • Nov 2011
    • 70
    Simultaneously.
    Driving along and my fuel gauge goes to empty with no warning light on, tach goes to zero and temp goes to zero.
    And my e-brake light doesn't turn on when the e-brake is engaged.
    What have I done to deserve this??
    Everyone gets diarrhea. Remember that.
  • bmw325csi
    • May 2007
    • 4045
    Sounds like your si board batteries took a dump on you.
    harry/harout
    • mr.vang
      • 4371
      check your fuse. on my previous e30, the fuse wasn't getting good contact causing the tech to died. i pulled it out and scrape it against the cement and it was working again.
      • Y30
        • Nov 2011
        • 70
        If its the SI board, can you buy them new? Or do you have to replace the batteries.
        I've heard some soldering is envolved... #notafan
        • bmw325csi
          • May 2007
          • 4045
          You can do either, I think its easier to just get a new or reconditioned one over trying to find the right batteries and changing them yourself.
          harry/harout
          • Y30
            • Nov 2011
            • 70
            Where do you find new SI boards? A quick google search yielded confusing and limited results.
            • bmw325csi
              • May 2007
              • 4045
              Guten parts
              harry/harout
              • Y30
                • Nov 2011
                • 70
                Awesome. Thanks.
                • Y30
                  • Nov 2011
                  • 70
                  Reviving this thread.
                  I purchased a new SI board and still no results.
                  I should mention at this time that every time I start my car I get a blip of life from each part.
                  My tach goes up. My mgp thing moves. My temp gauge moves. Then after 3 seconds they all peg to zero and don't function until I turn my car off and back on.
                  Anyone help? I do not feel like ripping my dash apart again if I don't have to.
                  Thanks guys.
                  • Y30
                    • Nov 2011
                    • 70
                    Also!! Important side note.
                    My fan for my heater/ac doesn't function. But does the same thing. 3 seconds of life and then turns off.
                    • Y30
                      • Nov 2011
                      • 70
                      Aaaaand another update.
                      Everything is functioning. I replaced the board and found a fuse had been blown somewhere in the midst of my tests.
                      I'll keep you guys posted.
