How to fit speakers up front (Diamonds)
  • permit
    • Mar 2005
    • 3363
    Ok, got my new amp in (Rockford 500/2), and the new Diamonds and crossovers installed, started up the stereo, and the front speakers are rattling at high volume. I was worried this would happen since the kickpanels touch the speaker, so now I need an easy way to fix this without doing some crazy custom shit like cutting away the kickpanel and fixating the speaker and grille outside the panel.
    Any ideas?
  • Jordan
    • 12911
    Is the stock sound deadening batting material still stuck to the back of the plastic kick panel cover? If not thats your problem.
    https://mtechniqueabs.com/
    • permit
      • Mar 2005
      • 3363
      Sound deadening is still there. I was considering the idea of a spacer to go around the ring of the speaker to press out the panel a bit, but I have no idea where I'd conveniently find something like that.
      • DSchultz325e
        • Aug 2004
        • 1158
        Put the grill on under the panel?
        I retired my E30 for now...
        E46 323i
        David Schultz
        • permit
          • Mar 2005
          • 3363
          Just measured it up that I can't use the speaker grille in any way or else it'll hit the hood latch. Would be nice if the panels weren't made of such shitty plastic, then I could heat it up and form it to bulge around the speaker. Oh well.
          • DSchultz325e
            • Aug 2004
            • 1158
            They should sell just plain old concentric rings with varied thicknesses, or you can make one with a hole saw. I dunno, I'd just relocate the hood latch if it were bugging me that much.
            E46 323i
            David Schultz
            • DrMcDave
              • 1793
              i was thinking about cutting the metal a bit and moving the speakers down about 1 inch it would fix every problem i think. this is just speculating because i have really looked into it fully. I know it woul clear the latch and the glovebox.
