Strange ACC power issue
    Hey guys.
    The othre day my car started doing this. I get no power in the run/ACC position when I start the car. If the key is out, and I turn it to the run/ACC position I get power to the windows, ac, and aux fan but when I start the car, I no longer get power to these things.
    The radio and the headlights, wipers all still work.
    Now, If i'm coasting and cut the key to the off position, and then turn it back to the on/acc position I then get power and can continue driving. Sometime they will cut back out after a while and I'll have to do the same thing. This is importand because I'm not running a mechanical fan and if the electrics keep going out I could run hot.
    Any idea?
    That sounds like a bad ignition switch
      Hmmm. I was thinking the same but, it would cut off randomly while driving or sitting still. The engine would still be running as well as the radio and cluster, just the A/C, radiator fan/ and windows would stop working
