Last night I remove my original factory antenna, which didn't work. I had been experiencing a parasitic drain on that fuse, which powers the antenna & cigarette lighter. I don't drive this car often so the battery will drain in a few days if not driven or charged. I usually keep it on a BMW trickle charger which plugs into the cigarette lighter to keep the battery topped up while not in use since I haven't dealt with the drain yet.
I purchased and installed a Z3 antenna base to replace mine so that I could use a short antenna. When I finished up last night all was well, my radio reception was very good, everything seemed ok. I plugged up my trickle charger overnight.
When I got in the car to drive it this afternoon, the battery was dead. I also noticed that the trickle charger's green light was blinking while the red was steady. Normally only the red light is on steady while charging, and the green light is on steady when full. Now, whenever I plug in the charger, I get a steady red and a blinking green; sometimes after a few seconds, sometimes after a minute or so.
The new antenna is not connected to any power source, only to the actual antenna cable. The old connecter for the power and remote (red and white wires going into a plastic connector) are connected to nothing right now, just hanging. What have I done wrong?
Apologies for the long post, just trying to accurately describe the situation.
