OBC light died
  • bowtie2bimmer
    • 830
    OBC light died
    So th eother week i noticed my obc light bar blinking. Then a few days later it was just out. The numbers still work just the lights are out. Now I know its not the bulbs. A) because I already replaced both with LED last ,year. B) I HIGHLY doubt both would go at the exact same time. So I am assuming there is a power to the board problem. Everything on the board seems to be tight. The blue plastic housing has a very small amount of play which I just assume is normal as I cannot pry it off the board or anything. Ideas?
    1987 BMW 325ic - Emma
  • Blackout
    • Apr 2011
    • 4125
    Loose contact?
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • bowtie2bimmer
      • 830
      The two prongs in the obc you mean?
      Sent from my DROID RAZR using Tapatalk 4
      • Blackout
        • Apr 2011
        • 4125
        Yes.
        » PARTS FOR SALE
        • bowtie2bimmer
          • 830
          They seem to be in there firmly... I can't get multimeter leads down there though...
          • treff-7
            • Sep 2009
            • 345
            If it was blinking for a while then there's a good chance that one of the LED's went out. I assume you wired 4 of them in series. I did the same thing and actually I'm replacing them right now. Mine has been blinking for years because when put the LED's in I spec'ed it for 12v. They are getting over 13v and that killed them. They didn't die completely but got dimmer a bit and started blinking. You can take the rear cover off from the OBC and check the voltage on the pins that way. Mine was 13.3v with the engine running.
