Z3 Antenna Swap - Grommet Issues
  • ncsubowen
    • Nov 2013
    • 1012
    So, I did the fabled Z3 antenna swap for my non-functioning retractable antenna, and everything went relatively smoothly (other than it being 25 degrees outside while I was doing it).
    Several other posters mentioned that the Z3 grommet fit rather perfectly on their vehicles, so I had one of those to go along with the installation, and I'm unimpressed with how it fits in the hole.
    My question is, did I get a bad grommet, is this how people have theirs, or should I work on modifying the grommet itself to better fit the opening?
    Any thoughts would be very appreciated. Excuse the dusty car, there's about a million leaves falling right now so I'm going to have to wait a week or two to clean her up.
    4 doors.. so much room for activities!
    IG @bluebombr
    Transaction Feedback:
    http://www.r3vlimited.com/board/showthread.php?t=323622
  • kungfooren
    • Aug 2013
    • 66
    I did this recently... It's hard to get it to fit, but once you do, it's a tight fit. I lubed mine in soapy water. You need to press down really hard to get the circle cutout in the rear quarter to fit in the groove/lip. Try a little twisting action. It took me a good 10 mins or work. It should fit fine.
    • ncsubowen
      • Nov 2013
      • 1012
      Hmm.. it was pretty cold so I'm sure that didn't help anything. I'll go out there and try the soapy water thing and maybe hit it with a hair dryer to soften up the rubber a bit.
      Do you have any pictures of how yours sits?
      IG @bluebombr
      • E30NJ
        • Aug 2013
        • 921
        yep. did the same, had to use soapy water and a good amount of force. you could try trimming down the grommet with sandpaper to try to make it fit a little easier.
        • StereoInstaller1
          GAS
          • 22679
          Dawn dish soap, no water needed. Use it for all rubber bits you install, forever, including windshields, subframe bushings, everything
          Closing SOON!
          Thanks for 10 years of fun!
          • Boris3
            • Apr 2007
            • 441
            Grommet too loose
            Apologies for resurrecting the old thread but I have the opposite problem. The grommet is too small/loose to the point that i can easily push the entire thing through the hole in the body and it falls into the trunk well. This is on 1991 318is.
            I ordered part number 65218389698 which is listed as the Z3 grommet. Is this the correct part?
            1990 325: track/racecar
            2003 330xi; project car
            2004 330i zhp: civilized car
            • george graves
              • 19997
              Not sure. IIRC there where two different antennas used on e30. Maybe some had a larger hole?
              Originally posted by Matt-B
              • Boris3
                • Apr 2007
                • 441
                Could be, or different grommets for the Z3 model years? Anyway for now some black RTV around the grommet to improve the seal seems to be the solution.
                • g.ruff561
                  • 1266
                  Resurrecting this old thread. What grommet part number is the best fit? I want to get it right the first time. I already have the mast and radio module. There are about 6 different grommets available. Thanks......G.
                  • M-technik-3
                    • 18946
                    My suggestion is purchase one for a 318Ti it matches the fender line better. It's probably cheaper too.
                    • g.ruff561
                      • 1266
                      Anybody got a junkyard 318TI vin to cross reference at the dealer? IJS.
                      • george graves
                        • 19997
                        Ijs?
                        • g.ruff561
                          • 1266
                          ........I'm Just Saying.......
                          • s1uma1
                            • Sep 2015
                            • 304
                            If you're still looking, this is the grommet i used and it fits perfectly in my 91 318is.
                            BMW Grommet 65218362369
                            BMW Antenna Base 65218375159
                            Good luck!
