Blinker Issue
  • brutus87
    • 6280
    Blinker Issue
    Hello R3v,
    I have been having an issue with my blinkers for a few days now.
    It will blink for a few times And then freeze,
    Or:
    I will put on my blinker and it will stay "stuck", it wont blink, doesn't matter what side. It is driving me INSANE. When youre outside, youll see the bulbs work because they are on.
    Could it be:
    The turn stalk?
    The bulbs?
    Something else?
    Thank you.
  • ELVA164
    • 4861
    Sounds like a stuck flasher relay. Replace with a known working one and check again.
    • FLG
      • Sep 2011
      • 3165
      Had the same issue, took out relay, cleaned and it's been good since.
      Sent from my SCH-I545 using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • brutus87
        • 6280
        Is that the relay underneath the steering column? Or is it in the fuse box?
        • FLG
          • Sep 2011
          • 3165
          Column
          • brutus87
            • 6280
            R3v,
            Thanks for the help, I replaced the flasher and it is good as new!
            • ELVA164
              • 4861
              :up:
              • FLG
                • Sep 2011
                • 3165
