Interior Dash Lights
  • fastnfurious7
    • Jul 2013
    • 53
    So, they all went out. The whole cluster, all the ones on the AC dials & the rear defrost and hazard buttons. All working when I drove the car to work and then all not working when I went to leave. Fuse is fine. Is this a bad headlight switch?
    Oddly enough...I had cranked the car to let it warm up with the lights off & I went in to grab some stuff in the meantime. When I returned to leave I noticed my rear, side marker lights were illuminated but no others. The switch wasn't pulled so no lights should have been illuminated. I turned the lights on, checked all lights around the car & found them all working properly. Sat in the car and noticed all the dash and console lights out. Any suggestions before I start testing everything?
    That could be the dimmer in the headlight switch.
    • fastnfurious7
      • Jul 2013
      • 53
      That's what I was leaning toward. If I can get one tomorrow I'll try and see if it remedies the ailment. Thanks!
      • fastnfurious7
        • Jul 2013
        • 53
        Took a little bit but I finally grabbed one (easy enough since my buddy has a BMW graveyard). Happy to say that it fixed the problem.
