Recently installed megasquirt in the car and now the windows wont go up ro down and the wipers dont work also the air doesnt work now either. Checked the relays and they look good. Is there a module or something else that could be disconnected or broken that would cause both to go out at the same time?
Front windows and wipers dont work
Did you test the relays?I will not forward tracking info unless there is a problem with the shipment. Allow a minimum of 7 days for delivery, a maximum of 14 days.
I sell a lot of items on a lot of forums, it is just to time consuming to have to find who everyone is by there zipcode on paypal, and cross reference a username on here. -
Assuming your starter is wired properly, it could be a bad solenoid in the starter itself. A friend had this same issue and that was the culprit. H/T to RobertK for the suggestion.Comment
