Battery Draining
  • Rev Run D
    • Feb 2013
    • 392
    Battery Draining
    Wife was driving the car, then for some reason the radio and antenna stopped working. Radio is an aftermarket JVC.
    Since then, there's been a drain on the battery, and the car loses charge after a few hours. Any ideas what's going on fellas?
  • ELVA164
    • 4861
    Well, sounds like a parasitic drain, probably related to a short in the aftermarket head unit. Buy a test light, disconnect the negative battery cable, clip the test light to the cable end, and touch the light to the battery terminal. If it lights up any more than a dim glow, you have a draw. Start pulling fuses until the light dims. Start with fuses 12, 21, 27, and 28.
    Once you find a source, remember it. Make sure the light is just barely lit before you stop checking for potential sources (the OBC and head unit memory draw a negligible amount of current). Next thing to do is start checking whichever circuit is affected. That will most likely involve pulling the head unit/driver knee panel to check wiring and/or pulling back the driver side trunk lining to check the antenna ground and wiring.
    • rcsoundn1
      • Nov 2012
      • 3361
      I had a similar issue. The above advice is great advice. I have had this before so I rewired the HU and the issue for me went away. PO had wires connected that were not necessary and I assume were the cause of the draw.
        A test light can work, but better method is to measure the current with a DMM. Normal parasitic draw would be 30-60ma.
        • Aleman
          • Mar 2012
          • 1608
          Try this procedure:
          R135 /// 1990 Alpinweiß II 325is
          └┼┼┘ /// 1993 Black/Black Convertible (sold)
          ..24
          • mjimport
            • Jan 2010
            • 418
            Just to add to this story, I had a battery drain caused by a power antenna that stopped working. I suspected it was the cause because the battery started draining very soon after the power antenna stopped functioning.
            I went through the process of pulling fuses and sure enough it was the antenna (fuse28?)
            It was drawing almost 1.3 amps! Just unplugged it and it stopped the drain. Now I need a new antenna :(
            • Das Delfin
              • Sep 2014
              • 2293
              ^ I just got a $10 Advance auto antenna. Although don't get the one I got, because the base has started to rust already! From just being out in the air! No salt or anything!
