So about a month ago I was experiencing a no start problem, got it towed to a mechanic, and for some odd reason it started up after that. While there had the CPS switched out. Car started up fine after that for a week or so, then one day I decided to pump gas. After filling up, I fired up the car and let it idle for a sec. A couple seconds later, the idle gets really rough and the car dies. I try starting again and it doesn't want to start. I wait about a minute and it starts up, so I give it some gas in neutral and drive off fine. The next morning it doesn't want to start up again.
I've been doing some tests and this is what I've found:
-No fuel pressure at all going to the engine when attempting to start
-Test light shows power at fuse 11 when starting
-Test light shows power at pin 30 on fuel pump relay
-Jumped 30 to 87 and still doesn't start
-Check the wiring harness to the fuel pump for power, two of three pins have power (assuming one is a ground)
Is it safe to say that I just need a new fuel pump, or are the more tests I should be doing?
1991 325i
1991 325i
