Hello guys .
A While ago , I changed my Sunroof rail pipes . and I couldn't find powered ones as my old ones were .
so I had to buy a manual pipe lines and cut a bit of the plate to fit the power motor .
anyways , now the sunroof switch can't be in it's place because , it turned out to be that the manual sunroof plate is not bended like the power one .
so the problem now here is that I can't use an e30 button ,.
so I took an E39 sunroof switch from a friend of mine , and now I need to put it instead of the e30 one , it will need a bit cutting in the upper dash but it's cool .
any ways . I need to know how to wire up the E39 button instead of the e30 .
I will not cut wire , I will use connectors , but I need to know the diagram of the button , also I know it has 3 movements with an auto ones , but I just need the open and close , and also if the tilt button is also a close it doesn't matter because it's already close/tilt in the e30 as you all know .
Cheers .
Cheers .
