early/ late cruise?
  • rcsoundn1
    • Nov 2012
    • 3361
    early/ late cruise?
    What year differentiates early vs late? I have an 87 and from what I am reading early cruise does not have a decelerate option. Does my car fall in that time frame of early? My cruise sets the speed and cancels it, but does not do decelerate, so before I go investigating I thought I would ask.
  • rcsoundn1
    • Nov 2012
    • 3361
    No info here???
      My 87 has accelerate and decelerate controls and I have never seen one on earlier or later cars that did not have both controls. If accelerate works and decelerate doesn't that is a fault in the switch, wiring or cruise control module.
      • rcsoundn1
        • Nov 2012
        • 3361
        Thanks for the reply, I was considering buying a known working stalk to see if that was the issue. Not sure I just want to toss parts at it, or do some real testing.
          The switch assembly would be my first suspicion. But a little detective work with the wiring diagrams and a meter will tell if the signal from the switch reaches the cruise control module. Which in turn tells you where to look for the cause.
