Need a continuity check between few wires on c101
    I tested my c101 plug on the body side (plug going directly to fuse box) and pins 15 and 7 are showing continuity. Can someone please verify if that is right or wrong before I start digging around looking for a short?
    Sent from my iPad using Tapatalk
    Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
    You will have continuity between both of those pins on the body side. Pin 7 connects to the Hot in Run and Start circuit, which also is connected to one side of the unloader relays. Pin 15 connects to the other side of the relays.
      Thank you, jlevie, I appreciate your explanation. Someone in this thread mentioned that I might have something wrong going on when I stated that I had continuity but it seems like I probably described the situation inaccurately.
      If you have some time I would appreciate you looking over this thread because I'm at a total loss of where to go from where I'm stuck
