So i'm stumped and trying to help my friend get his e30 working again. When he purchased the car it had a remote start button on it and worked by putting the key in the on position and then engaging the remote start. The car worked fine for two months, and then randomly the button stopped engaging the starter. Now the kicker here is that the key would no engage the starter. The problem is we have no spark or fuel now.
Things I have checked are the fusible link for the battery, CPS is brand new, when I went over the starter wiring it appears to be all intact, however we have no way of contacting the person who put the switch in as the person he bought it from bought it that way.
I am following this guide in order to check the basics and try and pinpoint what isn't sending the right signal.
The issue I am running into is i think i am misunderstanding where i am supposed to be checking on this guide. The first couple steps are easy and involved just checking continuity and resistance to the coil and ground. The problem though is the later steps say to plug the DME (i'm assuming this is the ECU) back in and reinstall the battery then check that power is going to the dme.
I do not know how i am supposed to backprobe the DME connector when its plugged in as there is no access to the back of the connections. Maybe I am checking the wrong area? Any help with this would be appreciated as I am tired of wasting time guessing and just want to pinpoint whats going on.
