Front speakers rattle
  • ST1G
    • Oct 2012
    • 6689
    I installed some new front speakers, and they are vibrating the metal that they are attached to. It's extremely annoying to the point that I've unplugged the speakers.
    Here is the portion of the metal panel that is vibrating. Any tips would be appreciated.
  • StereoInstaller1
    GAS
    • 22679
    have you dug around in there to see if there is some random part floating around, maybe a screw or something?
    I have never had a rattle issue there, not once.
    Get in there and kick its ass!
    Closing SOON!
    Thanks for 10 years of fun!
    • ST1G
      • Oct 2012
      • 6689
      Yeah, I pulled the speaker out and put a magnet down there to to make sure there wasn't a screw or anything. It's the weirdest thing. I put my ear down by it, and it feels and sounds like the it's the metal vibrating.
      • 15Michaeljoseph
        • Aug 2013
        • 1693
        a piece of foam? weatherstripping? you could stick it on there to buffer.
        --Mike
        (OO=[][]=OO) For Life
        • ST1G
          • Oct 2012
          • 6689
          Originally posted by DoctorLondom
          I had this same problem. See if the black cloth on the back of the plastic kick panels is loose. When it's up against the speaker it'll flap against it.
          It happens when there is no cover on the speaker at all.
          • Codym42
            • Mar 2013
            • 611
            --Mike
            These may help a little, depending on how bad the rattle is.
            http://www.crutchfield.com/g_762/Foa....html?tp=64142
            '90 325i - 5 speed coupe
            '05 330ci 6MT ZHP
            • AndrewBird
              The Mad Scientist
              • 11898
              Get some peel and seal from Lowe's and cover that area with it. It's in the roofing section. I used the same stuff to dampen the rear bulkhead in my old jetta. Got rid of all vibrations.
              But like Luke said, something else must be going on because that spot doesn't usually rattle.
              • ST1G
                • Oct 2012
                • 6689
                I'll get down there again today and listen for the rattle and see if I can see where it's coming from. I'll also pick up some peel and seal. Thanks for the advice.
                • dwvw
                  • Sep 2011
                  • 234
                  Is it rattle, or air coming through the holes in the metal. Also make sure that the speaker wires aren't contacting the cone of the speaker in behind when you mount it. I have a thread where I showed what I did to mount speakers for best performance there.
                  • ST1G
                    • Oct 2012
                    • 6689
                    I didn't think about the air moving through the holes, that might have been it.
                    I pulled the speaker yesterday, checked behind the speaker, and in the hole under the speaker. Couldn't find anything. I reinstalled the speaker, and speaker panel and it seems to be resolved. The speaker is no longer rattling
                    • dwvw
                      • Sep 2011
                      • 234
                      Could have been the plastic shield as well. AT least it's gone.
