Bought a car, fixed a lot of little things on it, but now I'm at a stop.
Headlights do not work, switch is good, relays are good and getting constant 12v but not switched to activate the lights. Flash the highs on the stalk and no high beam indicator.
Has anyone had their check relay circuit go bad? What are the symptoms if so? I can't think of anything else that would cause this, as the switch works and all other lights on the car work. However, the check panel does not indicate faulty front beams.
I'm hoping I'm just rusty as its been 4 years since I've really dug into an e30 and not really wanting to replace a fuse panel as that is where the integrated check system for the headlights is at. :/
