Car e30 318is 91.
so recently the signal indicator and hazard lights stop working. When i hit the hazard switch it stays on red, but no blinkers. When i signal left or right nothing happens.
-Ive change the flasher rely multiple times, ( the 1st time ive changed it with was with a brand new pelican parts, which worked for maybe 2-3 min then the rely went out. Since then ive swap it with multiple relays from the junk yard)
-Also change the hazard switch
-checked fuse 23 and changed
-checked bulbs are fine
need help, very unsafe to drive, almost thinking about taking the car to a shop.
thanks in advance.
thanks in advance.
