Head unit wiring - don't shun me I tried existing threads
  • Petebee
    • Jan 2008
    • 267
    So I have a relatively early ETA (2/85 prod. date) with the four speaker non premium stereo setup, including the fader switch in the dash.
    I've looked at several threads on how to connect my head unit (old Alpine detachable face cassette deck) to the factory wiring. After removing some junk from previous stereo I am left with the following "free wires":
    Wire Colors:
    Red/Green
    Yellow/Brown
    Brown
    Yellow
    Blue
    Blue/Brown
    Purple/White
    Red/White
    White
    Here are the wires that feed into the fader switch:
    Wires that feed into the fader:
    Yellow Black
    Yellow Red
    Yellow
    Blue Black
    Blue Red
    Blue
    Here are the speaker wires:
    Left Front
    Left Front colors:
    Yellow Red
    Yellow Brown
    Right Front
    Right Front colors:
    Blue Red
    Blue Brown
    Left Rear
    Left Rear colors:
    Yellow Black
    Yellow Brown
    Right Rear
    Right Rear colors:
    Blue
    Blue Brown
    Pic of wiring diagram from receiver
    I am pretty confident about making the connections for 12V power, main ground, switched power, antennae. It is the speakers that are driving me nuts.
    I assume that the "free" blue and yellow wires in the dash deliver the speaker signal to the fader, which splits them L to R (or front to back). Do I just connect multiple speaker source wires from the head unit to either the blue or yellow wire? If so, how? Or do I hack into the fader switch by wiring to the corresponding fader wires, for example:
    RF+ Grey (head unit) to Blue/Red (fader)
    RF- Grey/Black (head unit) to Blue/Black (fader)
    and so on...
    Help! Wiring is not my strong suit for sure.
  • StereoInstaller1
    GAS
    • 22679
    Unwrap more, until you get to the Junction of the fader wiring and the deck harness. Go about 6" past that Junction and pray you see more yellow/brown and blue/brown wires
    Closing SOON!
    Thanks for 10 years of fun!
    • StereoInstaller1
      GAS
      • 22679
      You MUST have 2 wires per speaker at the deck, you cannot combine any of them
      Closing SOON!
      • Petebee
        • Jan 2008
        • 267
        Okay so I pulled the console panel and took a pic:
        11 wires total
        Yellow/Black
        Yellow/Red
        Blue/Black
        Blue/Red
        Purple/White
        Red Brown or Grey
        Yellow Brown
        Blue Brown
        Red White
        Brown
        White
        The Blue and Yellow wires just led to the fader switch. I am thinking that the original radio just had L/R balance adjustment, and the fader switch adjusted signal for Back/Front adjustment. Original radio might have used the Yellow Brown and Blue Brown as the ground, Yellow and Blue as the signal to the fader, which then split it up to back and front. My left side speaker wires are all Yellow, and right side speaker wires are all Blue.
        I unwrapped the factory tape (still intact) several inches prior to the junction with the head unit wires/fader wires and I can't see any evidence of splicing or cut wires.
        How about this as a theory:
        Right front speaker
        Splice Grey (head unit) to Blue/Red (dash) for +
        Splice Grey/Black (head unit) to Blue/Brown (dash) for -
        Left front speaker
        Splice White (head unit) to Yellow/Red (dash) for +
        Splice White/Black (head unit) to Yellow/Brown (dash) for -
        Right rear speaker
        Splice Purple (head unit) to Blue/Black (dash) for +
        Splice Purple/Black (head unit) to Blue/Brown (dash) for -
        Left rear speaker
        Splice Green (head unit) to Yellow/Black (dash) for +
        Splice Green/Black (head unit) to Yellow/Brown (dash) for -
        The above would eliminate the factory fader and front/rear speaker pairs on each side would share a ground (i.e. two head unit wires spliced into a single dash ground wire).
        Does that seem reasonable?
        • modernist
          • Apr 2014
          • 283
          I think in the earlier cars with non-premium sound the ground splices are under the front seats, not in the dash. Not worth looking for. Mine is from 12/85 and is like that, anyway.
          YES. Don't use common grounds between speakers, that can fry a 4-channel amp. Bypass the fader entirely, it's useless. Use the factory + and – wires for the back, and run new + and – to the fronts. Be sure to twist the pairs, I failed to do that and ran into trouble with RFI. This was my troubleshooting thread, I also made a few diagrams.
          (correct me if I'm wrong, not an expert. just finished doing my own stereo, however. came out nice)
          1986 327i
          transaction feedback
          DIY thing
          meh
          • Petebee
            • Jan 2008
            • 267
            Thanks for the tips. I cut out the fader and used the factory speaker grounds for the rears. I'll run new twisted pairs for the fronts.
            Deck powered up but antennae is not picking up reception too well...had to graft in a new end plug and didn't realize that there is a small wire at the center under the white plastic sheathing. Will recut and solder that joint and try to reinforce it a bit.
            But the head unit works! Now to hunt down some cassettes LOL.
            • StereoInstaller1
              GAS
              • 22679
              Woot! Ya, coaxial cables suck... But you now have a grip on it, congrats!
              Closing SOON!
              • AndrewBird
                The Mad Scientist
                • 11897
                Add far as the antenna goes, radio shack sells connectors that require no soldering and work very well.
