Motorolie lamp
  • tomysss
    • Nov 2014
    • 41
    Motorolie lamp
    Hello, i took off the + cable for battery, and once i put it back on, "Motorolie Led lamp" started glowing next to the rear middle miror. How to remove that?
  • AndrewBird
    The Mad Scientist
    • 11898
    That light tells you your motor oil is low. First thing to do would be to check if your oil is topped up. If it is, start checking the wiring at the oil level sender. It is in the top of the oil pan on the driver side.
