Battery Drain
  • Steve Corbett
    • Jul 2012
    • 449
    Battery Drain
    I have an issue with my 1989 325I, The battery drains down after a day of not using it. With car off battery reads 12.5 volts, Engine running reads 13.5 volts. With battery disconnected at positive terminal, Radio disconnected and trunk light bulb removed, volt meter between terminal and battery it reads 12.5 volts. I removed each fuse and relays one at a time and got no noticeable drop. I figured I would see something?? Am i doing this wrong?
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
  • TimeMachinE30
    • Jun 2014
    • 3749
    13.5 seems low while running.
    Try a battery.. Free load tests at AAP or AZ.
    Then of course alternator.
    ACS S3 Build / Dinan 5 E34
    • MINIz guy
      • Dec 2012
      • 66
      When you have the multimeter between the terminal and battery, you should be reading current. When the car is in sleep mode, you shouldn't draw more than xx(?) milliamps. Any more and you have a drain.
      You shouldn't be measuring voltage in series anyway. You measure voltage in parallel.
      Now a 318ti
      • Steve Corbett
        • Jul 2012
        • 449
        Using an ammeter it shows 0.00 no matter what scale I use.
        Steve Corbett
        1983 528E Scrapped
        1983 528E Sold
        1984 745I
        1984 325E - Sold
        1989 325I Zinno
        1988 635CSI
        • AndrewBird
          The Mad Scientist
          • 11892
          I think you are using the meter wrong. Set the meter to the highest setting for amperage that it has. If there is a draw higher than what the meter is set to, it will fry the meter or at best, blow a fuse if it has one. Then you need to disconnect one of the battery cables and then connect one lead of the meter to the cable and the other to the battery terminal. Make sure you set the meter BEFORE you connect it, otherwise you might move through a lower setting while hooked up and fry it.
          If you touched both battery terminals with the leads of the meter, you fried it, no question.
          • AndrewBird
            The Mad Scientist
            • 11892
            Here is a good video explain how to do the test:
            • Steve Corbett
              • Jul 2012
              • 449
              Thanks for the video!! After watching it I realized I did not move the red lead to the Ampere side of the meter. Oops.
              Found 56 milliampere draw at fuse 21. Not much but something to run down.
              Steve Corbett
              1983 528E Scrapped
              1983 528E Sold
              1984 745I
              1984 325E - Sold
              1989 325I Zinno
              1988 635CSI
              • AndrewBird
                The Mad Scientist
                • 11892
                56ma is nothing. A single led is more than that. No way it would drain your battery over night, or even in a month of sitting.
                Are you sure it wasn't 5.6 amp, or maybe 560ma?
                • Steve Corbett
                  • Jul 2012
                  • 449
                  Yes, I have meter set to 200 miliohms and it reads 56.9. I am grasping at straws trying figure this out. My boy needs this car for school and I am getting flustrated. I agree it is nothing but it is all I can find at the moment. Going to check the engine running voltage again, but yesterday both my 89's were 13.5-13.8 and the 84 325E was 14.5 if anything the 84 seemed high.
                  Steve Corbett
                  1983 528E Scrapped
                  1983 528E Sold
                  1984 745I
                  1984 325E - Sold
                  1989 325I Zinno
                  1988 635CSI
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    Have you had the battery tested?
                    Are you running the car at all, giving it a chance to charge? Has it been sitting as you troubleshoot? Can you put it on a charger? Something to get the battery full?
                    Is the charging system working?
                    When was the last time you replace or serviced the battery?
                    Any other weird things going on? Lights misbehaving, stuttering, slow to start, dim headlights?
                    Have you done anything with the vehicle that predicated this issue?
                    • Steve Corbett
                      • Jul 2012
                      • 449
                      Originally posted by TimeMachinE30
                      Have you had the battery tested? I checked with my meter, 12.56V Will get load tested tonight. I also did swap in a known good battery.
                      Are you running the car at all, giving it a chance to charge? Has it been sitting as you troubleshoot? Can you put it on a charger? Something to get the battery full? I have had it on atrickle charger overnight. He is afraid of driving to work or school and getting stranded with it.
                      Is the charging system working? Shows 13.43V running.
                      When was the last time you replace or serviced the battery? Swapped in a known good one.
                      Any other weird things going on? Lights misbehaving, stuttering, slow to start, dim headlights? No other issues.
                      Not recently.
                      Steve Corbett
                      1983 528E Scrapped
                      1983 528E Sold
                      1984 745I
                      1984 325E - Sold
                      1989 325I Zinno
                      1988 635CSI
                      • JinormusJ
                        • 6887
                        I've had battery drain problems before
                        The first time it was a battery with a bad cell (got a warranty replacement)
                        The second time I suspected it was a bad battery (again), but I had it tested and it was good. What I found was 500mohms running through my ABS system that was starting at a short in the ABS relay.
                        Now, how this applies to you? Getting the battery tested is the first place I would start, then check the ABS if the car has it: there is no fuse for it and it's fairly easy for the metal casing to touch the inner workings of the relay and cause a slow draining short if it doesn't have the paper strip inside. If all else fails; I would then check the alternator
                        • StereoInstaller1
                          GAS
                          • 22679
                          Excuse me, you sure about that setting?
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • Steve Corbett
                            • Jul 2012
                            • 449
                            Took battery to advanced auto parts to get tested. Said it read twelve volts but only 200 CCA. It is a 700CCA battery. Put new battery in and will see how it works.
                            Steve Corbett
                            1983 528E Scrapped
                            1983 528E Sold
                            1984 745I
                            1984 325E - Sold
                            1989 325I Zinno
                            1988 635CSI
                            • beta14ok
                              • 283
                              Just in case you haven't checked it......remove the battery lead wires, clean the posts and clamps,....reinstall and snug it down well. Your battery won't last if the connection is even slightly loose.
