air fuel gauge hook up..
  • BMW2ner
    • Dec 2005
    • 462
    I have a used auto meter air fuel gauge, so I dont have the instructions.
    It has a purple wire
    a black wire
    and a red wire
    What wire goes to what color on my o2 sensor?
  • rs4pro3
    • 5808
    just a guese, but red=power black=ground and purple=sig. from 02 sensor
    85 325e 2.7 ITB'd stroker
    • Brew
      • 3060
      Don't bother hooking it up to your stock narrowband O2 sensor. Get yourself a quality wide band.
      '91 318is
      • np75
        • Apr 2006
        • 93
        I would make sure that it works with a wide band sensor before I did that. If it is set up to work with a narrow band O2 sensor, it probably won't work with a wideband. All you need is voltmeter to read a narrowband, but I think the wideband type needs a special controller. I do agree that the narrow band ones are not much good though. They are pretty much only good to tell you lean or rich, how lean or rich is pretty much a guessing game.
