or are they too big?
1" tweeters in factory location?
Too deep typically. check my thread on my "screens in e30's" I have a pic of my custom pod for my tweeters.sigpic -
1" Tweets should fit in the factory pods with no probs at all.
I previously had MB Quart tweets and currently Rainbow versions and both fitted okay (both larger than 1"). The Rainbows actually went in from the front as the grill and surround is all part of the tweet itself, but the MB Quarts went in from behind. To get the Rainbows to sit nicely I cut the pods back slightly to get the pod diameter the same size as the tweeters. Depth was not an issue for either.
Ian.Comment
props Ian, I was told I would have to modify them no matter what size i went, so I just built a new pod.sigpicComment
If you can't get them to fit or you want a cheaper solution (considering the very limited availability and high pricing of the premium sail panels), you can just get the stock ones and surface mount them and wrap them in vinyl or something to that effect. It will also give you some customizability as far as aiming the tweets optimally. Glassing them is pretty easy that way with the aid of some jersey cloth or something to that effect, too.I retired my E30 for now...
E46 323i
David SchultzComment
out of curiousity why would you want to mount them there? sound quality is significantly better if you can keep the tweeter within 8" of the woofer. I'm sure a better solution could be found with a proper mounting locationComment
The reason is that high frequencies tend to maintain a 'flashlight' type pattern. This means that if you put it down in the kick panel they wont be aimed right, period. It's a better compromise to have them up in the pillar than to have them in the kick panel.Comment
Originally posted by netcskThe reason is that high frequencies tend to maintain a 'flashlight' type pattern. This means that if you put it down in the kick panel they wont be aimed right, period. It's a better compromise to have them up in the pillar than to have them in the kick panel.Comment
Time alignment is pretty common these days, it wouldn't be hard at all to bring the higher frequencies back to spec.
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
Originally posted by Ray SmoodiverTime alignment is pretty common these days, it wouldn't be hard at all to bring the higher frequencies back to spec.Comment
Originally posted by ptownTSIso if i get the mbquart pce-216 should i mount the tweeters down by my feet in angled pods or just in the stock tweeter location?
If you are listening to music in which sound quality is not important (a great example would be hip hop) I don't really think going to all of this trouble will be worth it and you might actually be happier with the tweeters right next to your head in the a pillar pods. If you like music that uses real instruments (especially live performances) I think that you might be surprised with the difference that it makesComment
Originally posted by Nick325isThere was plenty of clearance between the door and the tweeter.
NickAaron
