E30 Base radio system install
  • rogue38
    • Jul 2011
    • 54
    This is based off a 90 325i without premium system, no amp, no fader. The stock head unit finally gave up the ghost and the speakers were shot. So it was time for a replacement. As much as I liked the base HU I decided to upgrade so I could have a Bluetooth phone system and streaming. I decided on the Blaupunkt Toronto 420BT. The basics: front and rear USB, SD Card, aux in, external mic port, IPod/phone direct control, Pre-amp 4-channel (2 V), and Sub-out. The last two I didn’t really care about but were nice if I decide to further upgrade later. I also bought two sets of Rockford-Fosgate R152-2 component set ups. Total price for everything was around around $280.
    Attached is the pdf. of the install to save on bandwidth and it would be easier to print out if you want. I skipped the obvious stuff as it has been covered several times on the forum. Here is the wiring for a base late production e30 wiring is as follows:
    Radio Wires:
    Radio Power (+) Violet/Grey Connector 216 (Hot in Acc., Run, Start)
    Radio Ground (-) Brown Connector 216
    Radio Memory (+) Red/Green Connector 215 (Yellow wire out of radio)
    Illumination Grey/Red Connector 215 (White wire out of radio)
    Power Antenna White Mine had both a 1/8” and ¼” connector available.
    Radio Speaker Connectors:
    Left Front (-) Yellow/Grey .174” Male Spade Large Connector 212
    Left Front (+) Yellow/Red .056” Male Small Connector 212
    Right Front (-) Blue/Grey .174” Male Spade Large Connector 218
    Right Front (+) Blue/Red .056” Male Small Connector 218
    Left Rear (-) Yellow/Brown .174” Male Spade Large Connector 245
    Left Rear (+) Yellow/Black .056” Male Small Connector 245
    Right Rear (-) Blue/Brown .174” Male Spade Large Connector 244
    Right Rear (+) Blue/Black .056” Male Small Connector 244
    Speaker Connections:
    Left Front (-) Yellow/Grey .110” Female Spade Small
    Left Front (+) Yellow/Red .189” Female Spade Large
    Right Front (-) Blue/Grey .110” Female Spade Small
    Right Front (+) Blue/Red .189” Female Spade Large
    Left Rear (-) Yellow/Brown .110” Female Spade Small
    Left Rear (+) Yellow/Black .189” Female Spade Large
    Right Rear (-) Blue/Brown .110” Female Spade Small
    Right Rear (+) Blue/Black .189” Female Spade Large
    Front Tweeter Wiring:
    Left (-) Grey/Green .189” Female Spade Large Connects to Yellow/Grey, Kick Panel White Connector
    Left (+) Grey/Yellow .110” Female Spade Small Connects to Yellow/Red, Kick Panel Blue Connector
    Right (-) Grey/Green .189” Female Spade Large Connects to Blue/Grey, Kick Panel White Connector
    Right (+) Grey/Yellow .110” Female Spade Small Connects to Blue/Red, Kick Panel Blue Connector
    Rear Tweeter Wiring: None
    2006 330i 6 Spd Man, ZSP, CA, SG, Black ette, Burl, Sat Prep.
    ED 29 May 2006
    1990 325i, 5spd, Calypso Red, Tan
  • Vanilla Gorilla
    • Dec 2006
    • 357
    Nice install. Looks very clean!
    • robrez
      • Jul 2008
      • 3376
      Great info!
      January 2012 COTM
