Hi, im new here and a new and proud E30 owner so cut me a little slack as i may ask obvious or simple questions with well known answers.
First off I have a 4 door 1989 japanese imported 320i.
My problems are:
-Tach/economy doesn't work but twitches once in a blue moon
-No connection to green service lights (literally no cords/connections behind the cluster)
-Rear driver side window is dead and doesn't work with switches that are known to work on console and door
-Check panel doesn't work properly (light comes on for the low beam with no bulb but the check button doesn't work the way Ive read its supposed to)
-Spedo dail is below the zero point on the gauge (hangs straight down)
How common are these problems and how hard are they to fix? How expensive? Thanks a lot!!!
My problems are:
